Timing Gear Cover Torque
Rick
10-18-2003 06:39:11
What is the proper torque settings for the aluminum timing gear cover to engine block 3/8" bolts and for the cover to side cover 3/8" bolts. Thanks much.
Rick
Dell (WA)
10-18-2003 07:18:12
 Re: Timing Gear Cover Torque in reply to Rick, 10-18-2003 06:39:11
Rick..... ....my Boeing Designers Manual lists 3/8-16 (NC) grade 5 torque spec at 33 ft/lbs. BUT is also sez "assembled value is not necessarily design value". Which I would interpert to mean that because the front timing gear cover is aluminum, don't tighten it too much because you'll warp and squeeze flow the aluminum cover. I have one table of torque specs that say 20 ft/lbs for front cover..... ...Dell
also....Bob
10-18-2003 18:18:51
 Re: Re: Timing Gear Cover Torque in reply to Dell (WA), 10-18-2003 07:18:12
My NASA space shuttle manual sez to torque them 32.456 ft/lbs for the 3/8-16 (NC). Mabee yur plane manyul aint gots nut'n to do wit a er..uh.. Ford N-cerial ti'min ger covar.
You are duh man Dell. I invee you. I aulways dremed of be'n a boe'n pilot.
respectfully...Bob
