Order Ford 8N Parts Online
8N Lift cover overhaul
Rick(Ga)
01-19-2001 19:34:41
I managed to get the lift arms off the shaft today. It took a lot of heat and pounding with a heavy brass hammer I borrowed from a mechanic friend. The brass hammer was not as harsh on the lift arm as a regular one would have been. Removed the cover and inspected the underside. Found the cam follower pin worn over 50%. I have been reading the archives about the cam follower pin but was not sure exactly what it was. Now I know. The ram arm was also worn some. There was a ridge on the left side of the cam about a 16th of an inch where the pin wore into the cam. I plan on replacing the lift arm bushings, hone ram cylinder and replace piston with an NAA style with O ring,(and now replace cam follower pin) pump relief valve and adjust linkages. I dont think the cam on the ram arm is bad enough to replace. Installing the cam follower pin should be a big improvement. My engine overhaul turned out so well I thought I would try to improve the hydraulic lift. It has been slugish for years. Thanks to all who have shared thier expertise on this board. Rick(Ga)
ZANE
01-20-2001 04:24:17
 Re: 8N Lift cover overhaul in reply to Rick(Ga), 01-19-2001 19:34:41
You are going to need some expert advice and something to use for a reference point to adjust that lift right.
See the attached link.
Steve IA
01-20-2001 03:14:36
Sounds like you're well on your way. Just curious, what made you suspect the lift arm bushings needed replacement? Removing the arms sound like a lot of work. Steve 8N 169302
Rick(Ga)
01-20-2001 07:09:26
 Re: Re: 8N Lift cover overhaul in reply to Steve IA, 01-20-2001 03:14:36
Steve, The left side lift arm had a lot of up-and-down play where the shaft comes out of the cover. The right side is fairly tight. After I got the lift arm off the bushing was'nt worn as much as I thought but still had a good bit of play or loosness. The bushings are thicker than I thought. I did not want the shaft to ware into the lift housing. Besides, the lift needed some attention anyway. Rick(Ga)
