Where to buy used implements?
Roger
10-18-2003 18:41:47
Does anyone have any suggestions for a source to buy used tractor implements (tiller, disc, etc)
I just want to get some idea of what these things should sell for if I find something.
Thanks
jimNCal
10-19-2003 10:20:00
 Re: Where to buy used implements? in reply to Roger, 10-18-2003 18:41:47
Roger, AFTER you check around to find out what your area wants for the different tools, start scanning the corners of the fields around you for the OBVIOUSLY unused stuff. I have been rewarded with some great deals and met some wonderful people with a polite knock and inquiry. Gotta dodge some big, ugly dogs once in a while tho. And get on the mailing list for your local autioneers. Auctions are a lot of fun and, like Dell says, go to the preview and decide BEFORE the bidding starts how high you will go on an item. Then STOP when you get out bid. Auctions have a way of getting more of your hard earned money than you wanted to give up. If you have light/sandy soil, get a springtooth. I don't even use my disc anymore. For me, finding the implements was almost as fun as getting the tractors, but the stakes are a LOT lower. Welcome to our world. Have fun and tractor safe. jim
gatractorman
10-19-2003 04:20:11
Check with your State Dept. of Ag. they will probably have a publication of used farm equipment for sale as well as other farm related items in your state, here in Georgia it's called the Market Bulletin.
Roger
10-18-2003 20:44:14
 Re: Re: Where to buy used implements? in reply to Dell (WA), 10-18-2003 20:22:00
Please explain "too high of a ground speed" for tilling. so...I shouldn't use a 3 point tiller with a NAA?
Dell (WA)
10-19-2003 00:23:22
 Re: Re: Re: Where to buy used implements? in reply to Roger, 10-18-2003 20:44:14
Roger..... ...every spring the N-Board gets the same question, "can I rototill with my N-Tractor?", and everytime the answer is still the same, ALL N's and NAA's are too high groundspeed for rototilling even with the dealer installed "Sherman" Under/Drive aux-tranny.
I can't find my tables right now to quote you exactly but its something like this. You need to operate your PTO at 540 rpms which is about 1800 rpms engine speed for max horsepower. Rototilling takes alotta horsepower. 1800 rpms in low/under is about 1-1/2 mph. Some rototillers require 1000 rpms PTO, thats about 3000 N-Engine rpms. The N-Engine is governed at 2200 rpms MAX.
The rototiller requires a ground speed of about 1/2 mph. This would equate to about 700 engine rpms and no horsepower and PTO rpms of 200. These arn't exact but are close enuff for illustrative purposes.
Howsomevers, there is a rare and fragle after-tranny aux-gearbox called the "Howard". It slows the ground speed by about 2/3's but does NOT slow the 540 PTO rpms.
Back in early 70's, when I was ranchin' near Lodi Calif, there were aux-engined rototillers that were 3-point mounted and pulled behind N-Tractors thru the vineyards. I don't know who made them.
Bottom line, N's ARN'T rototiller machines, but are 2-bottom plowing tools. (after all, thats what they were designed to do, replace horse drawn plows)..... ..respectfully, Dell
jimNCal
10-19-2003 20:54:51
 Re: Re: Re: Re: Where to buy used implements? in reply to Dell (WA), 10-19-2003 00:23:22
The Everett aux trans will also work. BUT, it IS a creeper! I WILL say that splitting a perfectly good running tractor into three pieces to install the creeper behind AND a Sherman combo in front of the 4 speed wasn't one of my best(stubborn) decisions. But I do love my Jubilee. Real wife friendly too! Oh well. 24 forward speeds and 6 reverse should be enough. BTW. After reading your responses to all the electrical questions in here, I doubt I'll EVER have to ask one of my own. Thanks. jim
Todd Ness
10-19-2003 03:59:04
I also read in the archives that some have used tillers on their N's. I guess it depends on the soil conditions, and how many passes you want to make on the same row.
Your mileage may vary,
Todd
