Hupp transmission
Archie
10-19-2003 15:41:35
I found a to-20 with what I think is a hupp auxiliary trans. in it.The motor is out and has a cracked in the block.I could not see the bolt like a sherman mounts.Would this fit in a8n????? ??? What would it sell for?????THANKS Archie
Willy-N
10-19-2003 21:02:17
 Re: Hupp transmission in reply to Archie, 10-19-2003 15:41:35
Not sure what it would sell for but it would fit. To get it off is hard you need to take the front of the Hupp off and use a allen wrench to get to the 4 bolts at the back. You will need a ball allen or grind it to clear the gears. You can't remove them all at once and just loosen them a little at a time till it comes off. It took me a long time to get the first one off because I pulled the gears out, the second one was easy to do. Wish I had someone to ask when I did the first one. Mark H.
