Battery cables
Rich
10-20-2003 10:07:25
Just yesterday I think I finally solved a nagging starting problem with my '41 9N. A few weeks ago, I had purchased a new 6 volt (three-year) battery from my Ford Dealership. It was quickly installed and I thought it funny that the new battery didn't seem to start the engine any faster than my (four year old) three-year battery. After a few days the engine refused to start and I tried every trick I new to get her going. I had confirmed that the battery was fully charged, the starter was good (had pulled it and tested it off of the tractor), removed and cleaned the conections on the start switch underneath the battery, the engine hadn't suddenly seized, the ignition key swith was fine and all of the wiring connections were clean, bright and tight. However, yesterday I did a much more thorough job of cleaning the battery cable connections and I was able to jump start her by by-passing the start switch with a jumper cable. She started right up and showed a positive charge on the ammeter. I ran her hard for at least a half hour. Upon shutting her off, she again refused to turn over. I suspect that one or both of the 2-guage cables from the battery to the start switch, or to the starter has a bad or loose internal connection. I had previously tested with my meter to see if the starter was receiving 6 volts from the battery and it was. The meter even showed that the start switch was behaving itself. After reviewing the archives, I couldn't find anything that addressed testing of the battery cables themselves. Is there any kind of test that would show if any of the 2 gauge cables have a problem? I'm thinking that the test could show if there was an internal breakdown and/or loose connection. I hate to order parts in the hopes that this will solve the problem. Any help would be greatly appreciated.
joe(NY)
10-20-2003 18:50:59
 Re: Battery cables in reply to Rich, 10-20-2003 10:07:25
Rich, I also had starter problems. I got new bat but didn't help. It turned out that my starter's bendix wasn't moving properly. It would get stuck in a position that would not allow the gears to the flywheel teeth to engage, although the starter would sometimes spin by itself. Eventually I couldn't even get a spin out of it. Result, I put in a new starter and started right up. Before you get a new starter you mighjt want to remove it first and move the bendix mechanism all the way back toward the starter and reinstall it. This sometimes does the trick. I bought a new starter because mine turned very sloooowly when it did turn at all. Just a suggestion I picked up on this board.
simple . . . Dell (WA)
10-20-2003 11:05:34
Rich..... ..with battery connected, just measure the voltage drop from end-to-end of your cable while cranking your starter motor. Should have "ZERO" voltage drop. Any voltage drop is internal cable resistance (corrosion). Ohmmeters don't measure low resistances like yer battery cable is suppost to be, (its a technical thing) but the voltmeter works just great.
BTW, them tharr wimpy 2 gauge battery cables for 6 volt N-Tractors AIN'T gonna doitt. Recommend one/naught (1/0) thicka yer thumb battery cables..... ....respectfully, Dell
Salmoneye
10-20-2003 10:29:20
I make my own 1 aught gauge (1/0) cables from fine wire welding cable and Wal-Mart special brass ends...Solder all connections and cut them to the exact (shortest) length...
Come in way less than $10/pair...
Only test I know is an OHM meter to see how high your resistance is on those puny 2-guage cables...
