Pilot bearing
ONT RICK
01-20-2001 14:44:32
I have split my 8N tractor and have removed clutch, pressure plate and throwout bearing, everything was going well UNTIL I tried to remove pilot bearing. Does anyone know an easy way to remove bearing? OR Do I have to remove flywheel?It's about 6 o'clock here in Ontario, Canada, minus 20 degrees centigrate which equals minus 5 degrees F. So I think I am finished for the day and am going to put my feet up and have a JD #7.
ONT RICK Thanks
DaBrow
01-20-2001 18:17:00
 Re: pilot bearing in reply to ONT RICK, 01-20-2001 14:44:32
Can't offer much help with the tractor problem BUT,I have developed the nack for mechanicly lowering the level in a bottle of Jack without special tools or equipment. ..DaBrow.
Tim
01-20-2001 15:19:24
The old trick i always use is to find a shaft or drift punch that slides into bearing.You fill the bearing with your grease gun,then take the punch put it up to bearing hole and give it a good smack with your favorite large hammer,this creates hydralic pressure behind bearing and pops it right out.The key is to have a drift punch that just slides into brg,without too much slop.Hope this helps,its always worked for me!
JerryU
01-20-2001 14:56:02
Pull the flywheel and knock it out from the back. No sweat. (Too cold)
JU
JimNC
01-20-2001 14:55:33
The easiest way is with a pilot bearing puller, but if you don't have one of those, you might try a bolt with a head just small enough to fit in the hole, put a chain on the bolt with a nut, chain has to be long enough to get a 2 pound hammer head in, that will be a make shift slidehammer. If that don't work, take the flywheel off. HTH Jim
