shifterboot
RandyinWNY
10-27-2003 10:48:01
Hi guy's, quick question, where do I find a place to buy a new shifter boot, and do I need to remove the shifter "plate" to install the new boot? Thanks in advance....Randy
stb tx
10-27-2003 17:04:57
 Re: shifterboot in reply to RandyinWNY, 10-27-2003 10:48:01
I use a piece of inner-tube, tied off with some nylon cord. Has worked well for years.
scott
Don't buy that junk...Bob
10-27-2003 15:00:47
If you buy one of those taiwan aftermarket boots that these guys are talking about, you have to cook it, season it, roll it in flour and fry it just to get it to fit. So I'd buy 2 of them in case you tear the first one installing it. Or buy a reproduction one that was made to fit and takes seconds to install. And there's no need to cook it until tender. LMAO!!
I know a guy in NC that sells them. Email me for more info if interested.
Bob
Chris Brown
10-27-2003 16:57:46
 Re: Re: shifterboot in reply to Don't buy that junk...Bob, 10-27-2003 15:00:47
I bought a chinese shift boot and the only way I could get it on was to use the air hose and inflate the da*% thing like a balloon and then it still didn't fit quite right. Get a ford boot!
souNdguy
10-27-2003 13:26:12
Along with what the other guys said.. I've had good luck at rolling hte boot up on itself a bit.. right at the bottom.. then down over the 'nipple' it mounts into. Make sure the groove it sets in is clean.. it will fill with crud over the years.
Soundguy
Dell (WA)
10-27-2003 12:26:24
Randy..... ....the shifter boot for the 8N is different than the 9N, but they install essentually the same way. TIP: carry your rubber shifter boot innna potta BOILING WATER to your tractor so it'll stretch eazily over your shifter lever and down over your tranny neck..... ...Dell
Steve(OR)
10-27-2003 11:31:50
No need to remove plate. Remove the screw on knob on later model 8Ns. Boot just slips over. Can't say for cast knobs.
Roger
10-27-2003 11:11:33
Hi go up to Lockport or any of the WNY Tractor Supply Company and get one.
Have it on the shelf
Roger in Buffalo
