Air cleaner
rich
10-29-2003 09:35:48
I have a great 1952 8N with a jar and bail type of air breather. Most pictures I see of 8N has a flat screen on the hood instead of this con glomeration. What are the merits of each? I plan to replace the jar and bail because I like to the flat one better. Was this an option? Many thanks. This group is fantastic!
P.S. What is a "hood pad" good for? I guess it fits aroung the radiator file tube neck. Thanks.>
Dell (WA)
10-29-2003 11:42:23
 Re: Air cleaner in reply to rich, 10-29-2003 09:35:48
Rich..... ....what you have is a dealer installed option commonally called a cyclone air pre-filter. Spins the heavy chunks out before they go down the tube to the oilbath airfilter. Some field work can be very dusty and extra filtering contributes to longer engine life. It takes some extra parts to reconvert to standard 8N trapdoor airfilter configuration..... .....Dell
Jborin
10-29-2003 09:58:24
Rich:
What you have is a Harco pre-cleaner. Air enters through the trumpet and is spun through baffles that create of vortex. The heavier dust particles are spun down into the glass jar. Lighter particles continue into the oil bath air cleaner.
Brian-2N
10-29-2003 09:54:02
Rich,
Hold onto the air cleaner extension. It's a pre-cleaner, designed to capture larger particles before they go through the oil bath. They were made by Harco.
They are fairly scarce, although aftermarket are still available. If you really don't want it, e-mail me.
