Order Ford 8N Parts Online
Rear end housing 8n
Randy
11-01-2003 07:42:58
I broke the rear end housing where the pinion is supported by a bearing in the tail end of the housing, I was wondering if that center section housing is the same on 2n or 9n . Are they interchangable with a 8n. Also what about the pinion and the ring gear carrier assembly.
Scott
11-02-2003 10:24:19
 Re: Rear end housing 8n in reply to Randy, 11-01-2003 07:42:58
The 9N and 2N housings do not have the 4 holes to mount the underneath drawbar and the hole to mount the top link rocker is smaller on the 9N and 2N than the 8N.
jimNCal
11-01-2003 15:50:54
As the man said, they are interchangable. There's one on ebay now and I have one I'd sell and guarantee.
Dell (WA)
11-01-2003 08:32:12
Randy..... ....according to my N-Ford Master Parts Catalog (MPC), the 8N-4021-B center housing fits 1939-52 N's. The differential cage assy p/n 9N-4210 fits 1939-52 N's.
If'n yer plannin' on changing all these parts, I'd suggest you consider the merits of having your own personal copy of the MPC. ($25 cheap) and a copy of the I&T FO-4 repair manual ($27 cheap)..... ...respectfully, Dell
