Order Ford 8N Parts Online
'52 8N idenitfiers
patrick
01-21-2001 09:47:05
Besides the serial number, what would be the distinguishing items that a '52 8N would have versus all other 9/2/8Ns?
Eddie S.
01-21-2001 19:21:14
 Re: '52 8N idenitfiers in reply to patrick, 01-21-2001 09:47:05
Also, the late '52s have enlarged rear axle trumpets to accommodate the inner oil seals.
Salmoneye
01-21-2001 10:48:16
Go here...Memorize this...There will be a quiz following...
patrick
01-21-2001 11:43:12
 Re: Re: '52 8N idenitfiers in reply to Salmoneye, 01-21-2001 10:48:16
Thanks! Good page!
Claus
01-21-2001 09:58:07
Without the serial number there is no way to tell an early 52 from a late 51. There was a change midway through the 52 year starting at serial number 442035. The transmission housing was enlarged on the left rear side to accomodate a larger gear for a lower reverse ratio. Late model 8ns had numerous changes such as the side mount distributor, plastic screw on transmission knob,regular automotive style coil. There are many differences between the 9N/2N and the 8N. Notably the 8N had both brakes on the right side of the tractor and came with running boards..etc..
Happy Motoring
Claus
