installing sherman tran???????????????????????
Archie
11-02-2003 16:14:52
I am intalling a sherman comb. in my 8n.The instructions are not real clear..Does a gasket go between the mounting plate and the sherman tran..????? ?????Ifso can I make one out of gasket material????? ???THANKS Archie
jimNCal
11-02-2003 22:44:32
 Re: installing sherman tran??????????????????????? in reply to Archie, 11-02-2003 16:14:52
Your gasket thickness may vary! Make sure the pre-load on the gears is set(with shims) so that turning the input shaft by hand gives just a SLIGHT bit of resistance when you put it in. Helix gears, Eh? Too loose and lots of gear noise. Too tight and much wear/shorter bearing life.
JimNC
11-02-2003 17:57:22
Yes and Yes. I used 3/32" material. It was very hard to find. Seems to be doing fine. Mine is a step-up but I think the installation is basically the same.
Jim
