We tried your kerosene trick to fix the lift problem with the 9N. It was a cold and messy business but it looks like we cleaned out a lot of gunk.The lift improved greatly in opperation. I hooked up the disc to it and it lifted fine all the way to the top and would go down ok if I put the quadrant down with in 5 seconds. If I raised the lift all the way up and let it sit, it would be stuck in that position until I dismounted and gave the disc a 5" lift then it would go down. The lift holds great in the up position. There is no creaping down over time like before. It is simply stuck there until I give the disc a small boost. The lift and hold has imrpoved as well. I can lift the disc up a foot and it stays fine but again, get stuck in that possition until I boost it. I am taking it to a guy to fix the governor at the end of the week and will have him check out the lift unless you have some last thing to pull out of your sleave. Thanks, for all of your input. Andy MN
