Order Ford 8N Parts Online
8N pulling tractor
Andrew
11-04-2003 19:57:48
I have a Ford 7.0L 429 Cobra Jet V8 its needs to be rebuilt.. If i found a good 8N ford would it be easy to make the 429 CJ bolt up to the trany in the tractor.... i would probly need a adaptor? would it be easy to make one???
Hobo,NC
11-05-2003 04:14:25
 Re: 8N pulling tractor in reply to Andrew, 11-04-2003 19:57:48
I have not seen one on a N. I have seen them used on about any engine they could be made to fit. Its about as good a starter that has ever been made. its small but thinks its a giant. Easy to work on and about the only thing that gives trouble is the two dollar set of contacts. If I had a bad flywheel i would use it as a replacment.
It will crank over a big HP engine were others will not.
Hobo,NC
11-05-2003 04:16:25
 Re: Re: 8N pulling tractor in reply to Hobo,NC, 11-05-2003 04:14:25
Don't know how this ended up here
duey
11-04-2003 20:40:50
An adaptor can be made or bought perhaps.... but think about that 30 HP transmission and 30 HP rear end, do you think they'll last very long?? Be a shame to get that far only to learn that you can blow up the gearing with one pop of the clutch. Even the Funk conversions, especially the flathead V8, needed to be respected.
If someone has had good success with high horsepower conversions, they don't often speak of their success in this forum.... duey
Dana
11-05-2003 07:17:01
 Re: Re: 8N pulling tractor in reply to duey, 11-04-2003 20:40:50
Duey is right. I'm thinking about the third or fourth time you rev that big v8 up you're gonna hear a loud POP in the rearend and then the tractor won't move anymore.
Andrew
11-05-2003 15:25:52
 Re: Re: Re: 8N pulling tractor in reply to Dana, 11-05-2003 07:17:01
Well the 429 i have puts out around 400H.P and will rev to 6000RPm :) i woudent use it to much it would be mostly for looks, but thats what i was afraid of the little 3rd gear wizzen by my head or rear end parts going out....I saw on the net a guy had a Ford 302 in a ford 8n... thanks
