No sparks.. if you do it exactly as it was written. Say you have the average old 6v pos grnd N.. with a weak battery.. and you need to jump it with your big beefy pickup truck..12v neg grnd. Get the jumper cables... hook up correctly to your battery ( though.. really doesn't matter at all here )... hooke one cable to the actual lug on the starter.. try to get the jumper clamp on the replaceable nut.. not the threaded stud itself.. you can replace the nut if it melts a little.. the stud is.. well a part of the starter untill it is rebuilt... Choose a suitable place for the other clamp.. say.. steering radious arm. the other fellow said ground.. but he was being realative.. as in . choose a ground in relation to the starter lug.. remember.. ground is polarity indescript.. ground is in reference to a specific polarity.. for instance.. on your 6v N.. where - is tied to the isolated start switch/relay.. + is grnd... etc. Also as mentioned .. the starter spins the same way.. reguardless of polarity. I generally make a habit of using the same 'ground' scheme on the jumpee/jumper vehicles.. i.e, if the jumpee is + grnd.. I hook up the cables the same way.. that way if there is a fault somewhere with the start switch... I'm just hooking 12 over a 6v battery and charging the heck out of it for a few seconds.. rather than hooking 12v up backwards to a 6v battery causing lotsa current to flow, as both batteries are discharging quickly... In all of this jumping to the starter directly.. remember.. #1, be safe.. get the tractor out of gear and in neutral... don't run yourself or others over.. irony is what gets you... you can have a tractor with a battery so weak that it won't spin the engine over and start.. then you get careless, and jumper the solenoid with a screwdriver while in gear and the darn thing not only spins the machine over in gear.. but starts it.... go figure*. Next... #2.. when jumping directly to starter... don't hit the big thumb start switch... that WOULD connect battery to battery... just make sure the ignition is on. * A little story here. we know our N's are starter interlocked.. a nice feature for a 50 year old tractor. When i had first got my 1966 IH cub.. i figured it had many more 'safety' improvements as it was nearly 14 years newer than my 52 8N. The day I got it, I ran it out of gas in the pasture, testing the mower. It just up and sputtered out and stopped. I hopped off.. ran to the barn, got the gas can and filled her up. Swung back on, and totally forgot thit it was in gear, pto engaged, etc. I pulled the choke, and hit the starter button.. which on a 66 is centrallly located on the dash. 1 rev started the engine, in gear, with the pto/mower engaged. My throttle was still set high where it was when i was mowing... so I went from a dead stop to mowing again in less than a second... good thing the 66 had the 'comfort' seat with a back.. and not a pan seat or I would have flown off the back with the cub speeding away at 3/4 throttle. I have quite a bit of respect for that starter interlock on the N now.. and also quite a bit of respect for the whoever built the starter on the IH cub... whoever it was... built a darn good starter... Soundguy
