Order Ford 9N Parts Online
is this normal for a 9N starter?
Rick
11-08-2003 16:52:22
I have just replaced the ring gear so it is ok. When I press the start switch, the starter ALWAYS engages the ring gear. If the engine kicks but doesn't start then the starter will spin free without engaging the ring gear. I then let go of the starter switch and let the spinning starter come to a stop. I then press the start switch and it engages the ring gear as it always does. IS THIS NORMAL?
max
11-09-2003 11:45:06
 Re: is this normal for a 9N starter? in reply to Rick, 11-08-2003 16:52:22
Rick
Have a 2n that was doing that. Was pulling the starter all the time, to figure out something to make it engage. Was while back. If I remember right I put a medium size cable tie round the starter shaft and trimmed off the excess so the bendix don't retract all the way. Kinda like a spacer. Fixed it. Haven't had the starter off since. Probably should pull it to see exactly what I did, like to have a few while I work on stuff. Hope to have been some help.
max
no . . . Dell (WA)
11-08-2003 19:10:18
Rick..... ....no, it is NOT NORMAL, just irritating. Just 1-cough of any cylinder will kick a weak springed starter bendix gear out of mesh with flywheel ring gear.
Depends upon your tolerance level, but the modern clutch style starter bendix hangs in longer, and doesn't kickout so readily $50..... ...Dell
Todd Ness
11-09-2003 04:48:38
 Re: Re: is this normal for a 9N starter? in reply to no . . . Dell (WA), 11-08-2003 19:10:18
I updated my bendix and it does the same thing and kicks out just as easily. But hey, who cares, must be a NORMAL thing for both the bendixes.
Todd Ness
old
11-08-2003 17:49:45
If I'm reading it right yes it is ok my 801 does it some times when I haven't started it in a week or two. Kicks the starter out and have a wait for it to stop again hope this helps
Phil
11-08-2003 17:48:36
yup, its normal.. i hade the same problem you just have to keep cranking it
Phil
11-09-2003 05:39:20
 Re: Re: is this normal for a 9N starter? in reply to Phil, 11-08-2003 17:48:36
i got my whole starter rebuilt and it still kicks out.
