Order Ford 8N Parts Online
Can 2N Steel Rear Wheels be mounted on 8N Centers
Arthur Brestlin
11-10-2003 15:04:18
I can purchase locally at a reasonable price original rear steel wheels as those that came with the "War Tractor" My question is: Can I mount them on 8N Wheel Centers? I was wanting to use them as an alternative to chains on tires to clear my gravel driveway of snow & ice. Would they fit, and is this a good idea? Thanks to any and all who reply! As always, all replys greatly appreciated!
souNdguy
11-10-2003 15:59:33
 Re: Can 2N Steel Rear Wheels be mounted on 8N Cen in reply to Arthur Brestlin, 11-10-2003 15:04:18
Besides what everybody else said.. steel is going to wreak havoc on a gravel drive... will mess it up pretty good...
Soundguy
Phil
11-10-2003 15:46:17
steel rims wont work on ice, as old already said, stick with chains, if you have a mig welder you can make a pair yourself, but if you dont want to wast time you probibly could got some at any tractor dealer.
Scott
11-10-2003 15:32:14
Ones made from 1939-1942 had 32" wheel centers and will not work on 8N centers but after 1942 they used 28" centers and are interchangeable with the 8N centers, I think it would be ok in dry fluffy snow on the flat but not in wet snow, ice or on a hill.
old
11-10-2003 15:28:45
Steel and snow don't mix well steel slides a lot on snow, even more then rubber, I found that out the hard way with a dozer a hill and snow. It was not fun as long as you keep going stright its ok but if you start slipping you can end up any where but where you want to be, and slideing sideways down hill on a dozer is not fun at all. Stay with the chains, if you check at state road dept. you can some times get used chains cheap. Hope this helps
Jeb2N
11-10-2003 15:22:39
Nope;
The center on the steel rims is made into the wheel itself, if i'm not mistaken, which means that it will only fit tractors with the large hub like the 2N or 9N. Sorry. Now you just have to get a 2N and a Zane Thang!
