Rich- Yep, you can do a tune-up yourself. I do recommend that you buy a Ford I&T 04 manual though. Great reference. This is one of those times I'd like to be able to "beam" myself over to show you exactly what to do. But, I'll walk you through it when you determine what I ask for below. First, realize that the 1950 model 8Ns switched from front mount to angle (side) mount distributors in mid 1950. You and I need to know which it is. If your coil is a separate canister from your distributor and your distributor cap looks like a normal 5-nipple one, you have a side mount distributor and it has a different tune-up procedure than a front mount. Let us know which it is. Since you are not familiar with tune-ups on these, I'm even more convinced your rough running problem is tune-up related. On the governor test, to remove the linkage, note that the ends of the linkage are spring loaded so you have to slide the ends outward in order for the little ball on the carb to come out of the linkage.
