I'M starting to CRY part 2
RussMO
11-13-2003 08:19:53
The dry compression check is as follows:
#4- 120PSI
#3- 120PSI
#1- 120PSI
#2- 120PSI
The #1 had the wet spark plug. I'm beginning to think CJim in Michigan is close. Maybe head bolts are linking antifreeze? Could a link into the #1 also cause the pinging? Does it make since to remove head bolts that go through water jacket and apply more gasket sealent?
Thanks
Tim long
11-13-2003 15:57:34
 Re: I'M starting to CRY part 2 in reply to RussMO, 11-13-2003 08:19:53
Check it hot and let us know,ok
jimmac (WA)
11-13-2003 08:58:12
Russ, It sounds like you're on the right track to remove your headbolts & use a good thread sealant w/teflon as a first step. You may have to go further if that doesnt cure your problem. Just my .02cents worth. Jim
John,PA
11-13-2003 08:24:16
Are you sure that the wettness is water and not gasoline?
RussMO
11-13-2003 08:32:10
 Re: Re: I'M starting to CRY part 2 in reply to John,PA, 11-13-2003 08:24:16
It's blowing white steam out of exhaust. Three of the plugs had a dry white ash deposit and the wet one was saturated with a liquid.
Thanks
Dan S (NY)
11-13-2003 09:11:36
 Re: Re: Re: I'M starting to CRY part 2 in reply to RussMO, 11-13-2003 08:32:10
Correct me if I'm wrong, but don't white plugs indicate that the engine is running to lean? Running lean can cause excess heat and could be part of the "pinging" problem and may have contributed to the leak starting. Just a thought...
Dan
Brian 2N Iowa
11-13-2003 08:55:45
If the bolt/gasket is leaking antifreeze, the head/cylinder/piston/plug would be clean due to the Steam cleaning it was getting. Taste the liquid and see, if sweet, it's antifreeze.
If wet from gas, the color would be similar to the other cylinders with the exception of the moisture content.
