Order Ford 8N Parts Online
Will hyd. pump from 9n/2n fit in 8n
Archie
11-13-2003 14:48:36
I have a 8n and need a hyd.pump.A friend has one in a 2n/9n that is good .Will it work in a 8n? THANKS Archie
Jim WI
11-17-2003 10:56:50
 Re: Will hyd. pump from 9n/2n fit in 8n in reply to Archie, 11-13-2003 14:48:36
Is this the pump in the transmission section or are we talking about an external front-mounted pump?
If the first, I think Hobo is correct. If the second, it should fit.
Hobo,NC
11-13-2003 15:10:50
linkhttp://hometown.aol.com/wzsherman/myhomepage/sale.html
Hobo,NC
11-13-2003 15:08:08
The hydraulic controlls or different. The only way you could use it would be to also use the hydraulic lift cover and linkage from the 2N-9n. You will then loose position controll. I would stay with the 8n set up or go with a live thang set up by Zane Sherman. Live Hydraulics would give you Bragging rights.
