Starting trouble
Andrew Feicht
11-13-2003 15:08:53
My 46 2n wont start. it will satrt once for a couple seconds but then dies. its getting spark and gas. for the past couple monthes i have been having trouble keeping it running. it wont run unless keep the choke out about half way. but then once in awhile it will run great without the choke. does any one have any idea what is wrong. I'm stumped.
old
11-13-2003 16:52:13
 Re: Starting trouble in reply to Andrew Feicht, 11-13-2003 15:08:53
I'd say you need to clean the carb/rebuild it if what ole said doesn't work. You probably have clogged up main jet and or dirt/rust in the bottom of the carb. hope this helps
Andrew
11-14-2003 11:52:31
 Re: Re: Starting trouble in reply to old, 11-13-2003 16:52:13
Thanks for the help! i rebuilt the carb and now it runs great.
Ole Henry (Va)
11-13-2003 15:51:42
Andrew, sounds like it's running too lean. Try backing the main jet (one in front of carb) out a little. Should be approximately 1 to 1 1/2 turns from full seat.
John A
Also....Ole Henry
11-13-2003 18:04:12
 Re: Re: Starting trouble in reply to Ole Henry (Va), 11-13-2003 15:51:42
...you may have a blown intake gasket or a cracked intake manifold. If you can get it running, lightly spray some starter fluid around the manifold, if it takes off and runs momentarily, the problem is there. need to remove the manifold and check out.
John A
