Fuel tank cleaning
Alan G. Abbe
11-13-2003 16:33:52
Bought 9N cheap. Renovated it. Painted it. Ran good. Took it out for a shakedown shredding cruise. It started overheating then fuel starvation from tank. Hauled back home (60 miles) Found an 8" ceder stick in the tank. Ends rounded off. How do I clean tank? Could the fuel starvation also caused the overheating?
souNdguy
11-13-2003 20:11:15
 Re: Fuel tank cleaning in reply to Alan G. Abbe, 11-13-2003 16:33:52
Are you sure you were overheating?
Is this the old style radiator.. or a newer presurized one? Did you fill it completely full?
Soundguy
LarryNAA
11-13-2003 16:59:01
Just thought of how this happened on my Jubilee: Chaff in the radiator caused overheating, then the fuel line vapor locked, because someone removed the sheet metal heat shield under the gas tank years ago.
LarryNAA
11-13-2003 16:53:34
Just guessing, but the stick might have been a home-made gas gage. Somebody dropped it in the tank. D'Oh. While unlikely, it's possible that running lean can cause overheating. Maybe when you get this 'fuel starvation', you're also running lean? But there are more basic reasons for overheating. And fuel starvation from the tank. I am in aviation. We call that 'fuel starvation', or:'running out of gas'.
Alan G. Abbe
11-13-2003 17:30:08
 Re: Re: Fuel tank cleaning in reply to LarryNAA, 11-13-2003 16:53:34
How can I clean tank without removing?
Tom A
11-14-2003 03:20:24
 Re: Re: Re: Fuel tank cleaning in reply to Alan G. Abbe, 11-13-2003 17:30:08
I think you probably have two separate problems, both fairly easy to solve.
My fuel tank had lots of crud in it. Actually had an old seed stuck in the little feed pipe out of the tank that caused the gas to flow just as a dribble...the engine would idle great, but under load it needed more gas and wouldn't run. So, (if you don't want to do the job *right* which means taking off the tank) I'd suggest you take off the entire float bowl mechanism, catch the gas flowing out in some container. Flush out any loose crud with more gas until the tank looks clean and the gas flows out clean. Then clean out the float mechanism, make sure the screens are clean and intact (mine weren't). Replace the mechanism and you'll probably be in good shape.
I doubt the overheating is related to the gas. I'll bet if you clean out the fins of the radiator, it'll cool just fine. My radiator fins plug up with chaff anytime I mow fields that I've let go too long. If I ignore it, the radiator just gets more and more plugged with dirt and dust and eventually won't cool well. First couple of times it happened, I forgot about the previous times and went thru a full cooling system troubleshoot first (stupid waste of time) before I looked at the easy solution. Now I look there first. I'll almost bet that is the problem with the cooling.
good luck,
Tom A
Rob N VA
11-13-2003 18:31:49
Alan,
I have heard that a radiator shop can chemically treat the inside of your tank. When I did my tank, I just got some big ol' gravels outta the driveway and dropped them in the tank and shook the dickens outta the tank until al the gravels came out. Then I took compressed air and blew out all the junk that the gravels knocked loose, and repeated the process several times. This is hard to do with the tank still in the tractor, but it really isn't that big of a deal to remove, just gotta make sure you get all the gas out!!!! Good luck, hope that helps--Rob
