Order Ford 8N Parts Online
8n 12volt coil for dell
Archie
11-18-2003 14:11:54
I order a 12volt coil for my front mount dist,on 8n,I thought I do not need the resistor.I burn the end spring of the coil..... ..... If I need the resistor than I will go back to the 6 volt coil..... ....Dell please educate me also I check all the resistor that I have (3) they read 12volts on both ends..... .....Does resistor cut the volt or amp down..... ..... .THANK Archie
Dell (WA)
11-18-2003 17:47:08
 Re: 8n 12volt coil for dell in reply to Archie, 11-18-2003 14:11:54
Archie..... ....any resistor cuts down on AMPS. More resistance, less amps. Its called OHM's LAW for a reason.
Resistance in a circuit uses up ALL the VOLTS. Y o u c a n s p r e a d out the resistance or you.can.scrunch.up the resistance and the voltage applied will be all used up. Its called KIRCHHOFF's LAW for a reason.
And the reason you read 12 volts on BOTH ends of your resistor is, you don't have a complete circuit. You have to measure your resistor voltages with the points closed so you have a complete circuit.
A good mechanic will "gently stretch" the springy-thingy under the squarecan frontmount coil for a positive contact that doesn't burn.
Sometime you can salvage a burnt contact with the same scrubbers you clean burnt food outta pottfer. Or fine file or fine sandpaper..... ...respectfully, Dell
