OT - OLIVER 66 info please
9n141
11-20-2003 17:28:42
Just bought an Oliver 66 and I know nothing about these tractors, Any and all info please. The oil pres is good, side curtains in place, starts good. BURT.
2fordsmike
11-21-2003 08:19:06
 Re: OT - OLIVER 66 info please in reply to 9n141, 11-20-2003 17:28:42
These are a good 2-plow row-crop tractor. Their best feature is an excellent totaly independent PTO and I suspect yours in so equipped. This is the little brother to the Oliver 77 (2-3 plow) and 88 (full 3 plow). most had a mechanical lift for the cultivator or other attachments, later models had hyrdaulics. if it has hydraulics you can buy after market 3-point hitch. A 66 is omewhat rare and desirable to Oliver collectors. However parts are fairly easy to find because of interchangability with bigger tractors. Mike-Iowa
old
11-21-2003 07:41:48
You should check out olivertractor.com Larry can tell you just about anythingyou would like to know about that.
JohN 50
11-20-2003 18:58:15
The first tractor I had after buying my property was an Oliver 66 RowCrop. Strong tractor, I built a FEL for it and worked the heck out of it. Traded it off because I have such hills I did not feel safe on it, plus I wanted a 3 pt hitch. It had a GREAT engine, never failed to start any type of weather, kinda wish I had back.
