Exhaust Manifold Studs
Rick
11-20-2003 18:40:42
What is the torque setting for the exhaust manifold studs (not the brass nuts - I've got that info) on the 8N? Also, what sealant, if any, should be used on the stud threads? Thanks much.
Dell (WA)
11-20-2003 19:13:31
 Re: Exhaust Manifold Studs in reply to Rick, 11-20-2003 18:40:42
Rick..... ...My Boeing Designers Manual lists the 7/16-14 manifold stud torque at 50 ft/lbs into the castiron block, use any stud pucky that pleases you. The manifold 7/16-20 brassnuts are torqued to 27 ft/lbs. I use high-temp "anti-sieze" on the brassnuts..... ....Dell, retired Boeing Flight Test Engineer
