I'm with you Old George trying to determine these kinds of things. There is a photo of a 2N tractor being painted in the Ford paint facility at the Rouge (page 128 'Ford Farm Tractors'). Perhaps, by the time 1942 arrived painting parts was modified, but, we can make an assumption that the process was similar for the 9N. The painter is spraying an entire engine, transmission and rear housing unit. Attached to the engine is the generator with belt, radiator housing, and radiator with hoses and clamps, carburator, manifold, and exhaust pipe/muffler, front spindles and hubs, all steering arms with grease fittings, throttle control quadrant and throttle control, and the spring to the seat (but no seat). It appears the distributor assembly is masked off. There is overspray on the radiator shroud and of course the generator belt. Your wire conduit is not installed at this point. I can't see the oil lines, but from what is there, the gauges and oil lines are missing. Of course, the fuel line is not installed at this time. On page 126 is a new 1939 9N in operation. The tool box bolts are cadmium, and the oil lines appear to be cadmium plated. Good luck, and if you stumble on some interesting nformation, share it...it's fun to learn these thngs. 9N'er
