Order Ford 8N Parts Online
8N Winter Put Away
Roger (NY)
11-25-2003 07:21:41
Have a 1952 8N first winter with it
Its down state at my hunting camp
What do I need to do to put away for
winter?
Will not be back to camp untell March
or April
Bruce (VA)
11-25-2003 07:59:24
 Re: 8N Winter Put Away in reply to Roger (NY), 11-25-2003 07:21:41
Fill the gas tank; add Sta-Bil, per the label, run the engine to get the Sta-Bil in the carb. Check anti-freeze. Make sure you have clean, not milky, hydraulic fluid, ie, no water in it as it will freeze & crack your pump. Change if needed. Remove the plugs, mist the cylinders w/ oil. Replace plugs. Place the tractor on jack stands/blocks; get the wieght off the tires. Block the clutch. Lube all fittings. Take the battery out & take it home with you. If you can't store the tractor in a barn/shed, invest in a good tarp & bungee cords. Keep it covered! In the spring, check very carefully in the air filter & under the hood for mouse nests, etc before you start it. And lastly, the 8N owners manual has a chapter on this, so check that out in case I missed something.
Roger
11-25-2003 08:35:22
 Re: Re: 8N Winter Put Away in reply to Bruce (VA), 11-25-2003 07:59:24
Thanks I just put new hydraulic fluid in.
Do I dran the gass in carb?
I just put up a shed for her, so will be inside
OH Boy
11-25-2003 08:55:32
 Re: Re: Re: 8N Winter Put Away in reply to Roger, 11-25-2003 08:35:22
I just turn the gas off at the bottom of the tank and let the engine run until it quits.
As long as you have Stabil in the gas I don't think having gas in the carb over winter will hurt anything, though.
