cut out relay points gap??
Rick
11-27-2003 03:35:01
I have what appears to be a perfectly good cutout relay except someone fiddled with the points gap. Does anyone know the correct gap?
bj/8n/mt
11-27-2003 05:42:46
 Re: cut out relay points gap?? in reply to Rick, 11-27-2003 03:35:01
Air gap isn't that important.
What you have there is basically a switch that should close at something over six volts and open at less than six volts. FO 4 gives 6.5 to 7.25 for closing voltage.
Your mileage may vary
raytasch
11-27-2003 05:24:04
Rick, Why would someone fiddle with a perfectly good relay? It is hard to see where problems are with 'lectrics. I would guess the gap should be small. Some relays require more gap so as to give the points wipe which makes better contact and keeps them clean. If the coil is good check the armerature for binds. A new cut out relay is less than $20.
ray
