S-james- Engines need three things to run correctly: 1) Good spark (whitiesh/blue) delivered to each cylinder at the propert time 2) Proper fuel/air mixture delivered to each clyinder 3) Sufficient compression. Assuming your tune-up was indeed thorough AND YOU HAVE whitiesh/blue spark, then turn attention to each of the three fuel screens in case they are gummed up. If all three okay, check for manifold leaks (not uncommon for a manifold gasket leak or burn-thru between exhaust and intake to develop). If above okay, then eithe your and your friend's carb need adjustment or rebuilding OR your compression is poor in one or more cylinders. Could be anything from a stuck valve(s) to broken rings to head gasket, etc... However, I'm guessing your tune-up was not complete. Replacing parts and regapping to specs is NORMALLY sufficient, but many other things can cause poor spark. For example, the little gounding strap and the insulator in your distributor can cause very poor performance (or none at all) or your starter or kill switch has an intermittent ground. MAKE SURE you have good spark or diagnosing from there can be a real pain...
