I CANT STOP
Phil
12-02-2003 12:45:32
Brakes dont work.. on my 2n unless i put a thousend pounds on them.. should i take apart the drum and order new parts or clean.. or is a more serious problem.... ive also turned that nob on the inside drum and no luck
Thanks
Chris Brown
12-03-2003 16:30:50
 Re: I CANT STOP in reply to Phil, 12-02-2003 12:45:32
Mine were oil soaked due to overfilling the transmission because someone put an engine dipstick in the rearend. I pulled the shoes off and soaked them in a bucket of gas over a weekend.Then I washed them with dish soap. They work great. One suggestion, swap the brake drums while you have it all apart.the 2N/9N driver usually only steps on the right brake and over 60 years the right side drum gets worn more than the left.
Ron from IL
12-03-2003 06:38:39
Phil,
I just did my brakes over the weekend. Check back on page 2 or 3 (the post is re: Well, wish me luck....). I described the process of replacing (at least my) brake shoes. It can be quite a job, but you can do it if I can.
Good luck!
Ron
SteveB(wi)
12-02-2003 20:56:39
Probably leaky seals and brakes are now well lubed. Look into installing "Sure Seals" if you take it apart to inspect and find oil soaked parts. Watch out, the Drum/axle assembly on a 2N is pretty heavy.
Lee
12-02-2003 12:55:13
Maybe just oil on them. Maybe worn out brake shoes. Can't tell until you look at them.
Good Luck, Lee
