Positive ground
Richard Malinau
12-04-2003 21:47:36
Can you charge a 6 volt battery in a 9N with positive ground without disconnecting the cables to tractor ? if so does positive from charger still go on pos of battery or negterminal? been disconecting cables to charge but is a pain
ZANE
12-05-2003 06:59:53
 Re: Positive ground in reply to Richard Malinauskas, 12-04-2003 21:47:36
No need to disconnect the cables to charge the batery on a 9N/2N or for any other battery except for later automobiles etc that are all electronic and computerized. Then you better disconnect the battery cables or you may end up in big trouble.
As long as the polarity is correct and the voltage is correct.
Barry
12-04-2003 23:39:55
Make sure your charger a 6 volt switch too. Read owners manual, because 12 volts can boil a 6 volt dry in a heart beat.
Also if you ever hook up a 12 volt system to a 6 volt system, for jumping, make sure of two things. Polarity wrong can blow a battery in your face and two don't leave switch on the 6 volt for long without cranking can explode coil. Have seen both happen first hand.
don t. - 9n180179
12-05-2003 04:44:23
 Re: Re: Positive ground in reply to Barry, 12-04-2003 23:39:55
JMHO....From what I've heard its never a good idea to connect a 12v battery to a 6v battery. Better instructions for jumping 12v to 6v are in the archives.
FWIW.....don t. .....
souNdguy
12-04-2003 22:03:35
Positive is positive.. negative is negative.. always hook up your charger by matching battery and cable polarities.. other wise you will get good sparks. Polarity of ground on that tractor charging system is only a realative issue. ( realative to the tractor ).
If your battery cutout works. no reason to disconnect your cables. If it doesn't.. replace it.. it is less than 20 bucks..
Soundguy
