Lifting arms wont go down
46 2n
12-06-2003 14:48:24
Well today i took my tractor pulling hitch off and put on my 3 point so i could put on the backblade. , i put on the hitch and then warm the fluid with a lamp and i raised the 3 point hitch. but it will not come down.. i drained all the fluid and i realized there was a lot of water in it.. so i orderd some new oil from my brothers store,i havent put the oil in yet.. not till wendsday when it comes in. The arms still wont come down after i drained the fluid.. what can i do to fix it, i also took off the inspection cover and there was a little ice, so im melting it right now.. how do i get the 3 point down.
Thanks
Bruce (VA)
12-06-2003 16:37:07
 Re: Lifting arms wont go down in reply to 46 2n, 12-06-2003 14:48:24
Hopefully, the ice has not cracked your pump base. If so, major problem; $500 buys a new pump. If the pump is ok, and the problem is a stuck exhaust valve, the arms should come down if you remove the right inspection plate, reach in and push the control rod to the rear. This opens the exhaust valve. While you're waiting for the hydraulic fluid to come in, clean all the sludge out of the pump base. You can get a lot out by hand, as well as by flushing it w/ kerosene.
