Valve cover removal
Paul
12-09-2003 06:55:11
Is it possible to remove the valve covers without removing the intake and exhaust manifold on my 52 8N? The tractor is running rough and I hear a rattling inside the engine. The sound seems to come from behind the valve cover closest to the front of the tractor. I was thinking this may be caused by a stuck valve. I have owned the tractor for about a year and a half and it has always run fine. This problem happened just as the cold (below freezing) weather hit.
Any help would be great. Thank you.
Willy-N
12-09-2003 08:15:48
 Re: Valve cover removal in reply to Paul, 12-09-2003 06:55:11
Yes you can. It is a little tight and harder to clean the gasket area if stuck on the block. Mark H.
