Swinging drawbar dimensions
Rick Clark
12-09-2003 08:28:55
I am wanting to restore an original "swinging drawbar" for Ford 8N. The inboard end of the drawbar (where it pins to the mounting bracket at the rear of tractor) has been cut off. Can someone tell me the correct original dimension of the bar from the inboard side of the roller box to the end of the bar? I also need to know the distance from the end of the bar to the center of the hole for the mounting pin (1-1/4"). I understand that the overall length of the drawbar is about about 33-1/2". Thanks for your assistance.
Philip, with pic
12-09-2003 09:46:49
 Re: Swinging drawbar dimensions in reply to Rick Clark, 12-09-2003 08:28:55
third party image
Rick, If this is the swinging drawbar you need dimensions of, I have a fully detailed AutoCAD drawing I can send you of it. Philip.
edk
12-10-2003 05:36:23
 Re: Re: Swinging drawbar dimensions in reply to Philip, with pic, 12-09-2003 09:46:49
hey philip!!!!! !!post that drawing
edk
12-10-2003 04:55:36
Philip
12-10-2003 05:15:03
 Re: Re: Re: Swinging drawbar dimensions in reply to edk, 12-10-2003 04:55:36
Ed, It is alot easier to send the information through e-mail if you contact me directly. Philip.
Mike OH
12-09-2003 09:06:45
Rick, I went out to the barn and measured mine. I get about 22 1/2" from the roller box to the end of the bar. From the center of the hole to the end measures about 1 5/8". And I measure about 33 1/4" overall length. All measurements were taken as the crow flys and does not take into consideration the bends in the bar. Looks like the length from the end of the bar where it attaches to the tractor to where it begins to bend upward is about 3 1/2". Hope this helps.
Rick Clark
12-09-2003 09:26:30
 Re: Re: Swinging drawbar dimensions in reply to Mike OH, 12-09-2003 09:06:45
Mike,
Thanks for your time and assistance. Those dimensions will definitely help restoration.
Rick
Rick Clark
12-09-2003 09:23:05
Mike,
Thanks for your time and help. Those dimensions will definitely help restoration.
Rick
