Electronic Tachometer for N's
Archer
12-09-2003 19:35:28
I've been looking at electronic tachs from Sunpro, etc. for my 8N with a pre-1950's governor. Problem is, all seem to be made for 12 volt systems. Is there any way I can rig one to work with my original 6 volt system??? TIA. Archer
Red Raider
12-10-2003 10:05:26
 Re: Electronic Tachometer for N's in reply to Archer, 12-09-2003 19:35:28
Northern Tool has 'em.
Dell (WA)
12-09-2003 22:30:12
Archer..... ...yer lookin' the wrongplaces for the wrong types of tachometers.
You can get a watch battery operated LCD "digital" tachometer that you can mount to your dash panel. It will work on 1,2,3,4,6,8 cylinder engines. It operates by inductive coupling by wrapping the sensor wire around any sparkie wire. About $25..... .....Dell
Dan
12-10-2003 06:16:23
 Re: Re: Electronic Tachometer for N's in reply to Dell (WA), 12-09-2003 22:30:12
Dell - where would you find these tachs?
Thanks - Dan
Dell (WA)
12-10-2003 07:24:21
 Re: Re: Re: Electronic Tachometer for N's in reply to Dan, 12-10-2003 06:16:23
Dan..... .....probably the easiest source for most people is J C Whitney..... ....Dell
Thanks.
12-10-2003 05:58:32
Thanks for the help, Dell. Archer.
CityBoy
12-10-2003 16:33:25
 Re: Re: Re: Electronic Tachometer for N's in reply to Thanks., 12-10-2003 05:58:32
Do an internet seach on TinyTach. It is what Dell is describing. J C Whitney has similar product that should also work just fine.
