is it true
rob ,Indiana
12-14-2003 17:58:17
that an model A or T,i'm not sure which, crank will fit an 9n. i've been going throuh the archives and haven't found the answer. i read that Henry like commonness in his products. i hope this is true because i have an late model A crank that i would like too keep ?.
Chris Brown
12-15-2003 05:44:12
 Re: is it true in reply to rob ,Indiana, 12-14-2003 17:58:17
Can't say. But a model "A" clutch disk fits and a ford military jeep clutch fits.
Bruce (VA)
12-15-2003 05:26:19
Probably not. I sold my last A Model in 1987, but as I recall the B Model Ford engine is closer in appearance to the 8N than the A Model engine. The A Model distributor was on top of the engine, for one major difference. Had the same fuel pump, though..... :)
bg
12-16-2003 05:00:05
 Re: Re: is it true in reply to Bruce (VA), 12-15-2003 05:26:19
I doubt that most folks caught the fuel pump thing.....;^)
I haven't been into a Model A engine since about 1965, so I can't remember, but it would be easy enough to compare the two if both were out of the engines. No doubt the camshafts are different.
Al in W. Mi.
12-14-2003 18:12:32
I borrowed a buddy's crank from his 1930 Ford when I was working on my 8N. It worked fine! I had the front bumper removed at the time - not sure if it would be long enough with this in place.
rob, indiana
12-14-2003 18:24:44
 Re: Re: is it true in reply to Al in W. Mi., 12-14-2003 18:12:32
i mean crankshaft.
Al in W. MI
12-14-2003 18:43:03
 Re: Re: Re: is it true in reply to rob, indiana, 12-14-2003 18:24:44
Sorry, I thought you meant hand-crank!!!
