Positive drive=clutch drive
ratface
12-24-2003 09:30:20
I posted a couple days ago about rebuilding a starter. Got some great responses. After taking starter to rebuild shop was advised that I could buy parts same price as rebuilder. He did tell me he was 95% sure problem was starter drive since it moves in both directions-rotates CW and CCW. Is the positive drive type the same as the clutch type starter drive. What is the one that needs the hole drilled in shaft called so I don't buy that one?
ratface-thanks Dell
12-25-2003 11:22:48
 Re: Positive drive=clutch drive in reply to ratface, 12-24-2003 09:30:20
Was hoping you would come along since most of the archive stuff is authored by you.
Dell (WA)
12-24-2003 10:06:04
Rattsy..... ...positive drive is same as clutch drive and DOES NOT require a new locking pin hole to be drilled..... ...Dell
