Order Ford 8N Parts Online
New NAA533-A Piston for my 8N HELP????????????
Archie
12-30-2003 17:46:43
Order anew NAA533-a piston for my 6n. Order a NAA533-A O Ring ana a Back-up washer.Does the o ring or the back-up washer go to the fluid side of piston????? ????? ????? ??Any help THANK THANK THANK Archie
BDK(TX)
12-30-2003 21:44:04
 Re: New NAA533-A Piston for my 8N HELP???????????? in reply to Archie, 12-30-2003 17:46:43
Archie, O ring goes to the pressure side. Hint to install the leather ring, Soak the ring in hot water bout 30 mins then get a atpered water glass from the kitchen ,slowly push the wet washer on the glass stretching itcarefully. let it set bout 5 mins ,slide it off the glass on to the piston then work it carefully into the groove. Worked slick for me. Good luck
Rich in TX
Bob - MI
12-30-2003 17:53:39
from the front of the piston:
O-ring then leather washer
Good luck getting the leather washer on, do a soak in hot water for about 20 min. to soften it up, then stretch it on. Don't boil it though.
Thanks Bob --Archie
12-30-2003 18:12:00
 Re: Re: New NAA533-A Piston for my 8N HELP???????? in reply to Bob - MI, 12-30-2003 17:53:39
