Order Ford 8N Parts Online
12V Conversion for 8N
Ryan MD
12-30-2003 17:58:01
I just bought a 1951 8N SN365242. The 8N current wiring situation is really bad a lot of cut corners. I would like to put on a 12V system. The kits includes Unicharge alternator w pulley, electrical resistor, wiring harness, top alternator bracket, base alternator bracket, alternator adjusting arm. What other parts will I need to complete this conversion?
Thanks,
Ryan
Dell (WA)
12-30-2003 18:17:14
 Re: 12V Conversion for 8N in reply to Ryan MD, 12-30-2003 17:58:01
Ryan..... ..follow the instructions religiously, and you should be alright. Most kits are full and complete, thats why they are "kits".
Some conversion kits require you to use your OLD 6 volt sparkie coil and a 12 to 6 volt converting resistor because its cheaper and it works. Me? I'd use a real 12 volt roundcan ignition coil and NO RESISTORS..... ....Dell
A 12 volt advocate for the right reasons. That said, I haven't found the right reason for my eazy starting 6 volt 52 8N, and I know how to do it right, the first time.
