I've always said that I was a 12 volt advocate for the right reasons. That said, I haven't found the right reason for my eazy starting 6 volt '52 8N. And I know how to convert it right, the first time. And its not because I'm an "originality nut" eather. The EMF hasn't moved me. Problem with 12 volt conversions, most are done for the "WRONG REASON". When Ol'Bubba down at the local spittin'-n-whittlin' club sez: "yep, thats tha' thing too due, converter to 12 volts" and pulls 'nutter' swigg onnna the barley popps. And everybodys heads nodd in sage agreement. WRONG REASON! Worst reason to convert to 12 volts: "its hard to start". Well yeah, wornout engines are hard to start. Engines that need a tune-up are also hard to start. 12 volts is just a bandaid masking a bigger problem. 'Nutter wrong reason: "starters bad". How do you know? To ears used to modern zippy starters on rice-rocket sewing machine engines, yep, N-Starters are SLOOoow, not necessarily bad. Last wrong reason: the electrically challenged re-engineered 12 conversion. Because there is NO STANDARD WAY to convert 12 volts (I know of 7-ways), some shadetree mechanics figger a little of "plan-A" plus some of "plan-B" and I'll have a jim-dandy 12 volt conversion. I read and answer this problem all the time. The ONLY TIME I would advocate a 12 volt system over 6 volt system, is when the economics of repairing a "BAD 6 VOLT" system exceeds the cost of a 12 volt conversion. As I say, there's nothing wrong with eather system, and if'n you want to convert to 12 volts for whatever reason, thats OK by me, I just haven't found a reason for me. Remember the 6 volt MANTRA: "keep 'em clean, bright, and tight". And don't be fer usin enny of them thar wimpy ferrin made battery cables. Gettcha sum 'mericun made 'arry chested one-aught (1/0) thick as yer thumb battery cables..... ...respectfully, Dell
