Carburator vacuum
Paul (MA)
01-03-2004 13:32:23
If I remove the plug in the intake/exhaust manifold on my 52 8N should there be a constant vacuum? When I remove mine I get vacuum with regular intervals of possitive pressure. Would this be caused by a burned out manifold or gasket, or is this normal?
Dell (WA)
01-04-2004 13:17:03
 Re: Carburator vacuum in reply to Paul (MA), 01-03-2004 13:32:23
Paul..... ...most 4-cylinder engines have a natural vacuum pulse. Try "dampning" the pulses by squeezing the rubber hose almost closed like you'd do a lawn water hose..... ....Dell
Clint
01-04-2004 15:38:28
 Re: Re: Carburator vacuum in reply to Dell (WA), 01-04-2004 13:17:03
Now waitaminit, Dell. Sure there are gonna be pulses, especially when the motor is thottled back to idle. That's becuz you only have 4 cyls pulling an intake stroke every other revolution. (4/2=2) So, at say 600 Rpm, you would have 1200 pulses per minute. But the throttle plate is closed, restricting airflow into the manifold, so vacum should decline relatively slowly as the air leaks past the throttle plate. And, it should never go positive, even if the duration between intake pulses is a millenium. The only way manifold pressure can go higher than zero is if an intake valve is pumping pressure back into the intake. I'd go with the sticking valve theory, although he didn't help himself out any by not telling us what problem he was trying to diagnose.
raytasch
01-03-2004 15:17:45
There should be constant vacuum of somewhere just less than 20 inches; 18-20 inches. If you are getting a wide rythmetic swing between vacuum and pressure I would suspect an intake valve sticking or spring broken. I have seen broken valve springs allow a good compression test yet cause a miss due to the valve failure to close.
ray
Paul (MA)
01-03-2004 13:36:37
Sorry forgot to mention compression is good on all 4 cyl. (about 100) so I am figuring it is not a valve issue.
