Stabilizer bars
Pitch
01-28-2001 01:38:39
to Bobm In response to the stay chain post you stated that stabilizer bars are not to be used with ground engaging equipment. Why not? I tried discing without the bars and the results were terrible the disc would'nt track properly and the tractive power was used up spinning and crablegging across the field. With the bars it was nice straight deep cuts using less power. Was I doing something wrong?
ZANE
01-28-2001 07:47:03
 Re: Stabilizer bars in reply to Pitch, 01-28-2001 01:38:39
The only ground engaging implement that I can think of that you cannot use the stabilizer bars with is the rear mounted row crop cultivator. The device that keeps the row crop cultivator going straight is the rolling coulter wheel in the middle of the cultivator.
The reason that you don't use stabilizer bars on the row crop cultivator is that being a rear mounted cultivator when the steering wheel is turned right the cultivator being on the back of the tractors tends to go left. If the stabilizer bars are used this makes the cultivator go sideways to the left and thus will plow up the crop.
