oil in rad
Al Deal
01-05-2004 12:40:11
I have a 1940 9n.she runs strong but lately I `ve noticed shes smokeing a bit.I also found some oil in the rad.I`m guessing a head gasket but would like any info ya1ll could give me.I have to change axel pivot shaft & bushing tomarrow,so I`ll be tearing her down in the AM. thanks to all Al
Scott
01-06-2004 05:29:57
 Re: oil in rad in reply to Al Deal, 01-05-2004 12:40:11
The axle pivot pin for a 1940 is not available anymore, you can get the bushing, you can have a machine shop build up the shaft if it is worn.
Dell (WA)
01-05-2004 12:54:59
Al..... ...yes, this is to confirm that the oily sheen you see floating on top of your radiator water is combustion by-products forcing past a weak headgasket seal. Time to replace. Torque headbolts to 70 ft/lbs, studnuts to 55 ft/lbs..... ....Dell
