Order Ford 8N Parts Online
8N engine oil
Ryan MD
01-05-2004 19:04:13
I would like to change the engine oil in my 51 8N. Does anyone have any recomendations on brand and weight.
Thanks,
Ryan
steve19438
01-06-2004 07:43:13
 Re: 8N engine oil in reply to Ryan MD, 01-05-2004 19:04:13
30W non-detergent year round here in eastern PA. whatever is on sale at wal-mart! (after all; all oils are created equal)
B. Jones
01-06-2004 05:00:08
In warm weather I have about 40psi oil pressure cold, when it warms up it drops to about 25psi. In the summer I use 15-40 as I feel it is an excellent oil. I don't start it much in the winter, but I still put in 5-30 in case I need to. Even with 5-30 I have about 25psi warm and about 10psi at slow idle. I really believe in a light oil for those cold starts, unless your going to pull the heck out of it and run it wide open. I WOULD NOT use non-detergent oil in any gasoline powered engine. If I was going to pull it hard I would use 10-30 and better yet use an engine heater.
old
01-05-2004 19:39:39
I use Valvoline racing inevery thing I have from my 1935 JD to my 1991 Geo tracker I've had good luck with it for 30 plus years and when I have had to overhaul an engine run on it found little or no where on parts but that maybe just me
souNdguy
01-05-2004 19:19:10
If you search oil in the archives.. you will find at least one or two opinions ( per member! ) about the subject.
I'll give you the skiny.
Original spec was sae 30, with some consideration for weather..
Some of us have a 'tired' engine.. and like sae 40.. to keep some pressure on the gauge.
Others like a multi weight.. like 10w30 .
Some report a loss of prime with the lighter multi weight.. but that is probably a symptom of a cracked pickup line, made worse by the lighter oil anyway.
Still some use synthetic products.... I hear even when it burns, it doesn't moke bad? can't verify that personally.
Then there's the Nh dealer recomendation.. mine says 15w40 ( just like for thier diesels.. etc.. and it is what they keep the shelf stocked with)
Next is detergent vs. non detergent. Some like the non/d and are worried if they convert to a det. that 50 years of crud will break loose. ( might ).And or rings that are sealed right now by crud will break free and loose compression and burn oil.. etc. About 50% consensus here for and against. Pretty much main suggestion is if you change to det. plan on changing the oil and filter often at least for a couple oil changes.
As for oil and filter brand? Use a good grade clean oil, and change that filter. You can get the filter just about anywhere.. it crosses with a fram C3 or C3p.. napa has it too? donno? 1010.. just a guess on that number.. someone will correct me if I'm wrong.
Most of those cartridge filters come with a new gasket.. use it.. and claen the oil cup good.
Also, service the air cleaner.. clean in solvent of choice ( gas or deisel / mineral spirits/ kerosene.. etc.. ), dry, and then fill oil bowl to the line with whatever engine oil you chose to use.
Keep in mind that a side mount distribuitor and the oem genny had an oil cup too.. a drop will do ya.. engine oil is ok.. but I use a litle precision oil can with some 3in one oil.. works great.
Good luck... I stayed unbiased on this as this is a 'holy war' topic.. like chevy vs. ford, footbal teams.. etc.
( I put valv. sae 30 in mine, and hit it with some stp 'old' engine treatment .. red bottle). I use a napa filter element if I have one.. though have used the fram c3, and one from an online dealer...all looked ~similar~.) Do whatever you and your tractor and pocketbook feels best with.
Soundguy
BOB
01-05-2004 19:15:05
i use castrol 30wt
