Reba..... ....there are 2 interchangeable jets in your M/S carb. The idle jet is 0.024 dia and the main jet is #49 drill (0.074 dia). Take a 1/16" (0.0625) drill bitt and use it a gauge. It'll go into the main jet, and won't go into the idle jet, pretty simple eh? ONLY the squarecan frontmount 4-nipple distributor requires the mandantory "infamous ballast resistor". The 5-nipple roundcan coil, no resistor, ok? Ballast resistors are like lightbulbs, when they go "bad" you don't get any sparkle. As I originally said, 5-15 seconds of run time is generally a bad condensor. BUT the 4-6 hours of "cool-off" time is indicative of a bad frontmount ignition coil that has been "COOKED" by overheating it with a by-passed ballast resistor. Your extra wire is almost a sure guarentee of a by-passed ballast resistor. Remember, the infamous ballast resistor is mounted on the dashpanel under the ammeter. It usually looks like a "spring" in a ceramic mounting block. Sometime white, sometimes black, ?quen sabe? The ballast resistor is mounted on a 3-terminal junctionblock. The center terminal comes from the battery somewere. Then one of your igntion switch wires connects to the same center terminal. The other ignition switch wire is supposed to connect to oneside of the ballast resistor terminal. The electricity then goes THRU the ballast resistor and out the otherside of the ballast resistor. The 1-terminal ignition coil wire is supposed to connect to it. If'n the 'lectrons don't go thru the ballast resistor to the coil, yer gonna burn out your squarecan 6 volt ignition coil. (and probably have) Unfortunately the OEM 6 volt squarecan ignition coil is NOT ROBUST as we'd like'm to be. Anytime someone tells me they replaced their sparkie wires, a WARNING goes off. Remember, the 4-nipple crabcap firing order is 1,2,4,3 CCW.....that means: sparkie #1 is connected to nipple #1 at 10 o'clock sparkie #2 is connected to nipple #2 at 7 o'clock now pay attention.....it gets tricky here sparkie #4 is connected to nipple #3 at 4 o'clock sparkie #3 is connected to nipple #4 at 2 o'clock vola', firing order 1,2,4,3 CCW, isn't that amazing? The amazing thing about these ol'N-Engines are soooo good, that they will run (eventually) mis-wired with only 2 cylinders sparkling. Hint: its usually the #3&4 sparkie wires that get crossed up. One other "obscure" short-runtime possiblity. Water in the gas. Take and drain a bunch of gas outta the carb drainplug into a glass mason canning jar and lettitt settle. I once drained 4 quart jars of cloudy gasoline outta my N-tractor. It took all day for water sepparate outta the gasoline. Smelled like gasoline, would even start but wouldn't run very long before stalling out. Don't gitt overwhelmed, the N-Tractor was designed for Model-T horsefarmers, you can operate a computer (grin)..... ...Dell
