20W ND oil
RandyinWNY
01-06-2004 11:12:41
Hello gents, Happy New Year to all.
Quick (and dumb) question. I use straight 30W non detergent oil from TSC in my 52 8N. With the very cold winter coming I was advised to use a lighter weight oil for easier starting. Do they make a straight 20W non detergent oil. TSC does not have any like this? Any input fella's?
Thanks....Randy
Duner Wi
01-06-2004 18:38:07
 Re: 20W ND oil in reply to RandyinWNY, 01-06-2004 11:12:41
You might try mixing 10w and 30w in about equal amounts to end up with about 20w.
edk
01-07-2004 09:43:06
 Re: Re: 20W ND oil in reply to Duner Wi, 01-06-2004 18:38:07
10 + 20 / 2 does not equal 20
they are different viscosities and therefor will not mix (kind of like oil and water... only different).
dw
01-06-2004 13:02:00
I use 30 weight detergent oil in the summer and 10-30 detergent oil in the winter. I have owned my 8N since 1969 and it uses no oil and runs really well. Would not recommend non-detergent oil in any engine, unless it was an oil burning junker.
B. Jones
01-06-2004 12:51:11
If you will ask people at the local coffee shop, they might tell you that non-detergent is ok. Of course you can get some people to agree with about anything. I think if you were to ask an oil company specialist they would recommend a Detergent oil say 5-30 or 10-30 or a 10wt or 20wt. It is hard to find 10wt or 20 wt so I would go after the 10-30 myself if I thought the engine was a bit worn. (Low oil Pressure). The people that know something about oil would not recommend non-detergent oil in an N-series tractor. In summer weather, I would use 15-40, 30 wt, or even 10-30 (10-30 if I didn't run it too hard). The old N-series engine is a good old engine if you'll give it some GOOD oil and change it regularlly.
Bruce (VA)
01-06-2004 11:52:42
Randy, I forgot one thing.....put 20w oil in the search engine above, then tell it to sort by date. Look at the posts from Dec 23 & 24. Lots of good info there.
Philip
01-06-2004 11:44:51
Randy, Personally, I would not use a non-detergent 20w oil. But anyhow, here is the answer to your question. Use google as a search engine and let your fingers do the walking. Philip. Link
Polish Mike
01-06-2004 11:41:35
Man ! Anybody wanna take bets on how many more times this question'll get asked this week ?
Happy New Year to you, too, Randy. You'll get 50 different answers from 50 different people on this topic, but my suggestion would be to use any good-quality multi-viscosity DETERGENT oil...you'll do just fine. Straight 30 weight non-detergent is old technology...your tractor will run just fine with it, but I'll stick with the newer stuff.
Do a search in the archives on this topic...you'll have enough bathroom reading material for the next 6 months...
Now I'll brace myself for all the personal assaults I'll get for giving my opinion....
Bruce (VA)
01-06-2004 11:36:59
Randy, scroll down on this page to a post yesterday from Ryan MD; a number of good responses to your question are there, along with a great summary by souNdguy as to the arguments on both sides of this topic.
