Squeeking up front
Al Deal
01-08-2004 13:55:41
1st off wanna thank all for reply (water in rad)Changed head gasket all is well.my 19409-N is later model so king pin &bushing worked out fine.
Now when she`s running at any thing over 1/2 idle,she`s squeeking real loud.thought it was oil breather but it is not. any ideas?Ijust put new 3 row 12 core per inch rad on er and thought may be fan rubbing but that ain`t it either???? Thanks Al Deal
Dell (WA)
01-09-2004 08:57:20
 Re: Squeeking up front in reply to Al Deal, 01-08-2004 13:55:41
Al..... ...you missed the MOST OBVIOUS, next to bad waterwater pump bearings, bad bearings in genny, LOOSE fanbelt..... ....Dell
Chris Brown
01-08-2004 17:43:18
Take the fan belt off and see if it goes away,if it dont go away it is in the engine somewhere,if so check the crank pulley first see if it is rubbung on something.
JimNC
01-08-2004 17:09:45
Al,
I put an engine in a piece of logging equipment, and the radiator was recored. When it was started up and run at around half throttle it made a heck of a squaking noise, thought the engine was going to blow again. Come to find out it was the air being sucked through the new core. When the outer screens were put on that slowed the air coming through and stopped the squak.
Just a thought.
Jim
rick
01-08-2004 15:25:39
Is the squeek happening when you are moving? Mine squeeked a high pitch when I replaced the king pin and bushing. I did not grease or oil it as folks suggest. I ended up putting a squirt of oil on the king pin and the squeek went away.
Al Deal
01-08-2004 16:27:28
 Re: Re: Squeeking up front in reply to rick, 01-08-2004 15:25:39
It makes noise when motor is running ,not moving.Iused anti size on kin pin for easyer removal down the line.
Geo in SD
01-08-2004 19:21:03
 Re: Re: Re: Squeeking up front in reply to Al Deal, 01-08-2004 16:27:28
You say it squeaks only when running? If it isn't the fan belt or water pump, check the distributor cam. Had experienced a Jubilee one time that squeaked like that, a little lube onthe dist. cam stopped it.
