3-Point Hitch Hydraulics won't lift
Ray Snow
01-08-2004 17:11:01
The tractor is a 1952 8N. In neutral, the hydraulics for the 3-pt will not lift the brush hog without me engaging the PTO and releasing the clutch. I thought that the hydraulics were supposed to operate without the PTO engaged and turning. I am considering buying this tractor but need your help. This is my first attempt at buying a tractor! Thanks!
SteveB(wi)
01-08-2004 19:08:01
 Re: 3-Point Hitch Hydraulics won't lift in reply to Ray Snow, 01-08-2004 17:11:01
then you need to look at this link.
Chris Brown
01-08-2004 17:31:52
Thats normal,just the way it is.
Ray Snow
01-08-2004 17:43:50
 Re: Re: 3-Point Hitch Hydraulics won't lift in reply to Chris Brown, 01-08-2004 17:31:52
Thanks! I would then assume that the PTO and lift hydraulics would activate in any gear(duh!) when the PTO is switched to the on position and the clutch released.
Bob
01-08-2004 19:15:09
 Re: Re: Re: 3-Point Hitch Hydraulics won't lift in reply to Ray Snow, 01-08-2004 17:43:50
Yes, any gear, plus neutral.
Chris Brown
01-08-2004 17:46:38
The PTO shaft goes through the hydraulic pump and turns it in the process.
