Order Ford 8N Parts Online
Checking 8N Compression for Valve Leaks
Ray Snow
01-08-2004 17:53:35
The 1952 8N runs a little rough. What can I expect in PSI when I run a compression check on each cylinder. I assume that low compression would indicate valve or ring problems. Thanks! New to tractors in Texas!
Dan
01-08-2004 19:24:56
 Re: Checking 8N Compression for Valve Leaks in reply to Ray Snow, 01-08-2004 17:53:35
Ray - over 90 is ok, over 110 is great. After you take the readings, add a little oil (2 tsp) into the spark plug holes and let it sit a while. Then take another reading. If the readings change 15% or so (or more) then your rings are worn. Also, you don't want more than 15 psi difference between cylinders.
Dan
Ray Snow
01-08-2004 19:53:31
 Re: Re: Checking 8N Compression for Valve Leaks in reply to Dan, 01-08-2004 19:24:56
Thanks for the great info! I appreciate it!
