Order Ford 8N Parts Online
8N side-mount distributor bushing
Paul
01-10-2004 06:12:17
I have completely disassembled my side-mount distributor on my 52 8N in order to replace the shaft bushing. How do I remove the old bushing? The shop manual shows it comming out from the top. Is this correct? Do I need a special tool to remove this bushing? Is there anything special I should know before installing the new bushing?
Thanks for your help!
JimNC
01-10-2004 07:33:51
 Re: 8N side-mount distributor bushing in reply to Paul, 01-10-2004 06:12:17
Paul,
I the best way I have found is to tap a couple of threads in the old bushing, thread a bolt into it then go to the underside and drive it out with a punch.
Jim
Paul
01-10-2004 11:26:34
 Re: Re: 8N side-mount distributor bushing in reply to JimNC, 01-10-2004 07:33:51
That worked great, thanks for the help!!
JimNC
01-10-2004 13:35:57
 Re: Re: Re: 8N side-mount distributor bushing in reply to Paul, 01-10-2004 11:26:34
You are welcome.
