cold out
Pitch
01-11-2004 03:38:46
Yesterday my 6 volt '49 started at -7f groaned a bit but she fired up stalled three or four times in the first coupla minutes. Had to engage the PTO and let her idle for another 10 to warm the fluid so she would'nt stall again, and this tractor is outside 365/24/7. I don't need no stinkin 12 volt!
Fred
01-11-2004 08:37:32
 Re: cold out in reply to Pitch, 01-11-2004 03:38:46
It is 0 degrees here in CT. I was going to go out and start my '50 8n, but....it's still 0 degrees out! Fred.
bj/8n/mt
01-11-2004 05:48:08
Try a dip stick heater in the three point. You will be surprised how much faster it gets the hydralics working--especially if you run 90 wt.
That is all the help my six volt n series get here in the Montana banana belt and the only start either one has missed wasn't the tractor's fault.
Your mileage may vary
